My 576 autotune has a rather high tickover!! is their anyway of formating the autotune?? or a way of resetting it!! letting it calibrate it's self!!
I hope this makes sense?!:confused1:
Many thanks
Shaun.
Hi, you cannot alter the settings at all. Are u sure its too high? Have u chkd the rpm with a tacho?
If it is too high chk the gap between the coil and lywheel magnets. Shd be .3mm
Change if neccesry. This may have an affect but most likely it is a faulty coil.
Make sure u are using a resistor plug.
I should have added it is possible to reset the autotune, but not re-map it. That may help...all u need is a 9v battery....jst not sure about the process tho.
