I've got about half an acre if wood which is 90% elm, much of which is dead or in the process. There is a little syc, ash and hazel too. I want to fell it all so that hopefully some of the elm may sucker and the others will coppice. I plan to fill in with ash, oak and hazel where there are gaps and long term have it as a coppice with oaks (probably not in my life time!).
Question is do I need a felling licence to fell all the DED elm? The remaining broad leaves will fall into our quarterly allowance but all the elm will take it way over.
If its dead then no, if its dying then yes. I would say to be on the safe side get a felling license, if you do an EWGS 1+4 (i think from memory )rather than a straight felling license you should be eligable for a restocking payment to help pay for the trees going back in
I thought the exemption was for the 3 D's?
Dead, Dying or Diseased
thats TPO's not felling licenses
To be fair if your felling a licensable volume of timber and removing it you would be safer getting a license rather than facing a compulsory restocking order from FC if they dont believe you it was all dead (dying isnt a valid reason), as this is a very costly process and there is no grant aid if its compulsory restocking
