Has anyone made a footlock strop out of Ice Tail, using a big eye one one end for the klemheist, or whatever you use, and a tight eye on the other end for harness attachment? So inbetween the splices its just a single line? I made one up using locking brummels, but is this acceptable?
I think with locking Brummell and tails buried at least ten times the diameter so 80 mm should be more then fine make sure you always lock stitch it!
I've made an adjustable 1 for a rope wrench when I get one for the hand ascender that toggles tight onto the foot similar to a whoopsie sling with straight buries and it seems fine.
So if it's your prime attachment then locking Brummell bury and lock stitch! Will be Kool like that mate.
