Rayco rg1625 clutch problem
willburt
It's electomagnetic. You can dismantle them very carefully and have them relined. They have to be lined by a specialist as the linings are glued on cold to prevent damage to the electronics.
You may find the bearings have contaminated your old linings with grease so you should replace those too. I think a genuine replacement is about £400.
