[ATTACH]101691[/ATTACH]
[ATTACH]101692[/ATTACH]Back again, thanks for the part number info. What I am really trying to find out is this is (using Oregon part numbers) a bar 208SLHD005 Which is on my saw, see photos, the same as a 208SLHD009 which is the actual part number recommended by everyone. The 005 bar fits but i havn't worked out if it is reducing the oil flow. I'm trying to eliminate things before replacing the oil pump and buying a new bar
D005 bar mount was originally fitted we stopped making this about 15 years ago and replaced it with the D009 pattern, so both are correct for your saw, you would find it hard to locate a D005 mount today.
Thanks Rob D and Les that was the info I was after. It looks as if I will have to look at /buy a new oil pump because even at setting 4 the chain runs dry.
