Rigging down a lighting struck Pine tree
T.C
When you are ropping the trunk down you should use a chogging cut and then push it off or let it slide off on its own. Its alot faster than doing a felling cut and then using a wedge and hammer. Your making more work for yourself than needed also because its tough to push wood which has a hinge with the weight of the wood included. I saw you struggling abit on this so I thought I would at least mention it.
But having a gob and back cut lets you have control over whats coming down.
Only thing I could pick out of that job was cut accuracy on some cuts but other than that good job!
