My Carb has H,L,LA adjustments. Filter cleaned including fuel filter. ..
It might be better to replace the fuel filter entirely rather than clean it. I don't think you can get the finer bits out.
I had a similar problem on a saw, and it was right after I'd replaced the fuel filter.
Funny you should have this issue. My 450 has just started doing the same thing! The last machine I had which did this turned out to be a combination of things. A carb gasket was one, and the fuel pipe had a tiny hole which cased it to get air in the system. Does the primer bubble run dry? Mine did and that's what gave it away apparently?
Hopefully it's a simple fix. They're good machines.:thumbup1:
