My understanding is you get a basic ticket then you can work under supervision. How do you get the experience to progress to do your own work?
Has anyone thought of doing a course and is it worth doing? Diversification and all that?
I would imagine it would be better to have an engineering qualification for inspections etc?
Thoughts please.
Rigg Access is the forum.
The Best way in for wood cutters is to get into Geotechnical squad, the ones i know are CAN, TRAC, Rock Solutions, Geo Rope and QTS group. you'd pretty much need a PTS ticket as well for the railway but your employing company needs to sponser you.
You can get in as just a rope tech, you can end up painting and cleaning stuff. I've been silo cleaning (with a confined space ticket), bird netting, gutter fixing........
You start off the IRATA system as a Level 1. you are trusted with very little until you can prove yourself. Level 2 deems you competant and level 3 makes you a supervisor.
You don't have to be an IRATA company or work within IRATA guidelines, but like everything it shows competance and training.
How's that?
Jamie
  • 3 months later...
rigg access, is the forum as jamie said. lacks the answers that maybe arbtalk would provide. a lot of questions like 'I'm a level 1 can't get work' makes the whole prospect disconcerting. i started training up as an industrial rigger, as a lot of it is applicable to what we do. wind turbine work also seems a growth sector. it has the catch 22 problem of can't get work without experience can't get experience without work
If you can get on with a Geo company they'll give folks tons of chainsaw work.
QTS work all over the country and the tree boys go ahead of the rock squads. I've heard Geo Rope have a contract out in Afganisthan if that appeals.
Jamie
i guess its a good way to get your level two. will they sign off your hours? did a bit over rail ways in oz. some good views. pretty repetitive. i can only assume the money is probably less than tree work as its not as technical
