Bar/chain for 335xpt ?
Tractor62
Hi guys my 335xpts chain snapped yesterday and I was wondering what you guys would recomend as a decent replacement the bar fitted is a 12" Oregon 91 however it had a dolmar chain fitted and after checking with my elecy micrometers the bar groove is between 1.52-1 .64mm and the chain drive links are only 1.28 ish. I'm guessing the bar should be closer to 1.3mm so am thinking just replace both and know that everything matches as it should
The 12" bit sounds fine, a 1.3mm gauge would be best, the pitch would be whatever the sprocket is but would expect 0.325".
Have a word with Rob D on this site, he will give you a good deal and advice for that matter!
