5837 rpa's?
sloth
Ok, maybe I am looking at this wrongly through sleep deprived eyes, but:
- BS5837 section 4.4.2.6 says measure stem diameters to the nearest 10mm
- section 4.6.1 says diameters measured in accordance with annex C, and RPA determined from annex D
- annex D has diameters in increments of 25mm, so that RPA radii (is that even a word?!) increase by 0.3m a time, for ease of laying out protection on site presumably.
Should RPA's be taken from annex D, or is it just a guide? Or, should they simply be plotted on the TPP as 12 times stem diameter?
Thoughts and opinions please.....
I think that Annex D has been added to the recently revised BS5837 in order to simplify things a bit tbh.
So from my understanding, you measure the stem diameter and round the figure up to the nearest increment in Annex D, and plot the RPA (radius or area) using that.
I use software that does it for you ;)
My opinion on it anyway, hope this helps
The thinking behind rounding up RPAs to the nearest 10mm is to try and stop people submitting reports with RPAs specified to the nth degree. I imagine most people calculate the RPAs using a formula in Excel but don't bother to edit it to a sensible level of accuracy before copying the tree data table in to their reports!
The table in Annexe D makes it easier to determine a RPA without doing the calculations yourself, but personally I'll still use my own calculations as I find this quicker.
The fun(!) bit is doing the maths for multi-stemmed trees now!
that makes sense, however I can't find any reference to say you must round up to the nearest increment in annex D?
I am trying to set up an Excel spreadsheet to do it for me, somehow incorporating the rounding to annex D figures, if need be. And yes, multistems can be a pita...
Ta
