Output on any processor depends on the diameter of the timber you are putting through it, the length of log you are cutting, if you are using a loading rack, if you are single handed etc.
Looking at it then it looks similar to my JAPA 700, with a load rack and a teleporter working single handed cutting logs from about 75mm to 300mm dia at 240mm long I do about 2 cube an hour, thats about 1000 saleable logs. That includes time spend loading the rack and stacking away the processed product. If I was cutting at 480mm then I would be doing getting on for four.
A
Edited by Alycidon
Fantastic machine owned one for two years, put about 800 tons of timber through it, and all it,s needed is new crimps on the infeed belt cost 10 pounds and just had the the blade sharpened, they are well built and reliable, i,m pleased i bought a Posch and not a lesser machine. :thumbup:
Read more
