As per the title anyone got any info as to which helicoil I will need to get?
From what I can see they are all the same size, I just dunno what size that is!:blushing:
Just measured one, it is definitely M10 (10mm dia) the thread is finer than 1.5 and 1.25 and a M6 1.0 tap was a snug fit when meshed with the thread so I am thinking M10 1.0 thread and am pretty sure (90%) this is right but just don't have the tap and die to test it.
That is pretty fine - you will need the square bottoming tap to get the thread to the bottom of the hole, also be careful when drilling - Husky are clever and have a small decomp outlet hole that stops broken decomps entering the cylinder - a very smart move:thumbup:
Nice one, cheers for the info mate.:thumbup1:
I thought it must be a metric size just as you say though its quite a bit finer than your standard M10.
Ill buy an m10x1.0 and let you know if its the right size.
