Does someone out there have for sale, or know where I can buy, a Fan Housing part number 112 112 540 for a Sachs Dolmar 116 si.
The cir clip that retains one of the spring loaded starter pawls came off and the pawl destroyed the fan housing. It's a nice saw to use and I would very much like to get it back into operation.
I am in Australia but would be happy to buy out of the UK, US or Germany if needs be.
David
Edited by motty
Add info
hello matty
if you go on the uk e-bay there is some dolmar 116 parts the part you are after might be there
hope that helps albert
Thanks for the tip Albert. I had a look but the part I need is not there.
The part alongside what I need is there and a fan housing for a different model of saw is there. Close but no banana!
David
Additional information on the part required.
Fan Housing P/No 112 112 540
Or
Starter Assembly P/No 114 112 630 (includes above part)
According to the IPL these parts will also fit the 120si which hopefully increases the chances of someone having what I need.
David
