no stress function just not working on my tw125 , worked when i got it but after 1day it decided , nar , im going to piss you off --- so been taking it easy
any ideas people.
once i get this problem sorted il be a happyier tree hugger , already replaced the engine the other week so this is hopefully the final chapter
i can probly forget that idea of wires near ignition as all engine / key start etc towards front has just been replaced out the box from honda - problems been there before and after engine repalcement
is there any relays anywhere ? need to download a manual later just thought i ask in case anybody been thru it all before cheers
Take the control box off and check its dry inside, then seal it back up properly. Mine plays up from time to time and it's always the buttons.
Hi Dr Green
If the rollers will feed forward when on full revs, (which is 3400rpm for your machine) and the no stress does not stop the roller feed at the correct point it sounds like the drive belts are not tight enough and slipping.
What happens then is the sensor does not pick up the rev loss via its sensor quick enough.
You could give Timberwolfs Technical help a call on 01449 765820, they are always happy to assist.
no stress doesnt work at all ... rollers work perect including stop,start,forward,reverse...
probly not belts as just had engine replaced , so now and before new engine it was exactly the same
as revs drop as you feed in (if it going to drop too much i stop start stop start rollers to keep revs up)
sensor maybe - will have to sort it out - not a tool used everyday but still should sort it :)
Read more
