Kohler 25hp engine
Stu Cedar
Hi People
Wounding if any ones got a Kohler 25hp engine kicking about in there yard or work shop that they want to sell. i dont mind if its working or not long as it aint smashed to bits and i can rebuild it
If any one can help id be very greatful
Cheers Guys
Stu
Thanks lads its has to be a kohler 25 iv just brougt a dosko stump grinder with a kohler 25 on it but the engine has completly had it, the cam snapped and 1 of the conrods has cracked the block so a 25 hp it has to be so all my clutch and that will fit..
Thanks for your help lads il just have to keep looking
Cheers Stu
Kohler command 25hp engine with what looks with a tape measure to be a 36mil shaft. I'll be completely honest with you I brought it with the intention of rebuilding it and fitting it to one of my chippers, but I've upgraded long ago. It does run, but was pouring out black smoke. One of the exhaust studs has snapped off apart from that it should be ok. Shame your not closer really as it's a long way away to take a punt on.
R
