It is realy Beal. This lanyard i spliced for friend in Sweden, but i climbed with same long time and for adjust i used 8mm Ocean prusic. Working without problem, only this Beal is at beginning little bit slippery in hand. In gloves with ruber it´s good.
Thank you Drew! I like this cover-protector for example on eye sling for block and i used for lanyard too. I think, it´s good protection and eye will be hold longer time without damage. What do you say, it ´s ok or no?
its all good bro,personally i dont think its needed but if you like it then sweet as. i think youll cut the lanyard before you wear the eye out!! :)
