Sign in to follow this
ArthurG
Stihl 039 - fix or skip?
While it's not widely published the fix on the Zama carbs is not a big closely guarded secret .In addition many times the carb has been blamed for problems they really didn't cause .Such as worn crankshaft bearings which allowed side movements to the crankshafts resulting in air leaks after the saw had been running a few minutes .
In just the US and Canada the amount of good crankcases on flea bay is stagering and they are cheap .This only points out that those 020 and 200T's that didn't die from a fall from a tree had their pistons cooked from air leaks and not all of them can be traced to a bad Zama carb .
Edited by Al Smith
Share this post
Link to post
Update:
got the oversize stud from Mr Solutions on Friday, along with some spare bar nuts and a new helmet. It went on a treat and my old 039 lives again, all for £2.35 and P&P.
Many thanks to all for their input and especially Spud for pointing me in the right direction. :thumbup:
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
