It is very interesting stuff indeed especially when you think a 60cm can generate 10kn of force!
Although im not convinced that dropping an 80kg weight is the equivalent to dropping a 80kg person.
Surely the harness will absorb some shock so will the person compared to a block of steel.
Now there's a good point about the harness. I have seen some folk use them for rigging so it'd be worth bearing it in mind for that too!
