Case 580f lives again.
elfinwood saws
Spent the last 3 days fitting an engine in to my digger, i took the engine out of a David Brown 995 and had to swap bellhousing, flywheel, clutch to torque convertor, sump, manifolds, change all the timing gears so they would match the power steering pump gear and lots of other little pieces. Just got to cure a leak on the back arm and sort out a windscreen. I can start digging my swimming pond now :thumbup:
