What killed this Oak
Gollum
this photo shows lots of similarities to extremely active Armillaria (mellea probably) dryadeus tends not to have so much mycelium, and generaly there is more coning at the butt, whereas this is confined to the smaller roots and is at its most intense on the outer layers as opossed to inner and or undersides.
IMO of course, armillaria is certainly the key player here and is very capable on weakend oaks.
[ATTACH]87001[/ATTACH]
This is dryadeus, still quite a bit of mycelium.
But there is more of a uniform failure
Hi Gollum, would you be so kind as to take some more pics when you start to cut it up? One just above the butt would be nice
No problem.
was going to anyway
will post once done.
I will count the rings and measure the stem circumference
yes, thats more what I would look for in Inonotus failures, the cone in the butt is there as are the remnants of the upper portions of the root still in the ground where they would be.
this wouldnt happen if the tree was vital, takes a lot to enable dryadeus to get this bad.
