Vemeer 935i fuel issues
_tc
Hi guys I let my chipper run dry of fuel as it was on a steep driveway and conked out. I have tried re bleeding system and fitted a new filter. There is no manual primer on it so cracking off the injectors and cranking on the key but not having any joy.
Has anyone had and experience bleeding these suckers up?
fit your own primer pump from a motor factors then you can bleed it tot he pup inlet manually. and crack off injector unions and crank to finish it off, or just keep cranking with them open, the fuel will get up there eventually. with a tank that big though you must have been doing some serious chipping to run out!
Ok got there this morning and it would turn over at all, turns out the starter was burnt out in trying to bleed it up. Bloody thing. Will fit manual hand pump inline and get it as far as I can before cranking again.
Thanks guys
Will report back.
  • 1 month later...
Just to keep you posted, I got the bugger going. I just started again, bleeding to filter then to inj pump then injectors. Thank god for that. Nice to have her back as the fire site was getting a bit full.
