Anything you do to the exhaust will void Stihl's warranty. Also you will likely need to retune the carb to maintain optimum fuel to air ratio and your carb will likely have a limiter cap on the H screw which may need to be removed.
If you do decide to change the direction of the exhaust, the easiest way would be to get an 023/025 muffler and remove the deflector and make your own to direct the exhaust the other way.
Aspen is a good suggestion also.
