Can anyone help with a contact for a mobile miller. Would just need one operative and mill. The beech is 1.2m dia x 3m long and located to the rear of a Victorian house. Access is restricted by a path.
Also anyone interested in the planks or sections once cut?
Thanks
How wide is the path?
If it's narrow, you're probably restricted to a swing mill that can be built around the log, or a chainsaw mill. Are you planning to use most of the timber? If not, be aware that you may well not get your money back on beech just by selling it.
I do have a chainsaw mill that would do it, but it would be very slow unless you're wanting big slabs rather than thin planks.
Alec
The path is approx 4' wide and is located off Lexden Road in Colchester.
How much would we get for the green slabs, have seen that dry can get anything from £25 to £90 / cu ft.
Yes that's the beast. They seem to have taken more off of it now.
Yeah, I ringed it up as requested leaving the smaller section until somewhere was found for the fire wood! The client originally had storage but that seems to have fallen through!
