climbing knots
jamesivor
Sounds to me like your problem is not the knot (unless your tying it wrong) but more likely the type of cord you are using, try another type of cord maybe thinner than what you are using now. Rule of thumb usually is if you have a stiff climbing line then use a softer cord or if you have soft climbing line then use a stiffer cord. Pretty much all cases your cord should be thinner than the climbing line.
