Where about are you mesterh?
I have been doing cctv for 10 years so if your near by i could come and give some advise, as i said before it is very hard to build a system unless it is well thought out
To be honest the first link has pretty poor cameras (low res) they would be ok if they where low leval and very close to whatever you want to monitor, so not ideal. Also there is no hard disk with the recorder so you would need to add another £60+ for an decent disk.
The second system is better al round, even though it says super high res they are not. I would say they where hi res but no amazing. For the money though its a system that should do what you need. You will just have to experiment with placing the cameras in different places. I would recommend temp fixing them for a couple of days so you can see what works and what does not, then install them properly when you have found the ideal locations.
Cheers for checking them out.:thumbup1:
As long as I can remotely operate a flame thrower from them then that will do for me.:thumbup:
Haha that would be awesome and is not that difficult to do
