200t misbehaving
mark_goldfinch
When an ignition coil fails it prevents the machine from running, not from stopping. Failure to stop is common for the reasons mentioned here by others, i.e either of the two wires, quite easily fixed.
Carburation issues,however,are not uncommon on this saw and the problems may be coincidental to the repair.
I may have been a bit hasty with my last post. I seem to remember that I did have to replace a coil once because the earthing tag had corroded and broken off flush with the resin.
