i own an 04 model 150 and of late its being a right pain in the arse !!
it will run for an indefinate amount of time no problems,then all of a sudden it will stop for no apparent reason,no coughing/lack of power etc it just dies!!!
turn the key and it bursts straight back to life??!!,could then mayb run indefinatly then again or cut out as soon as it draws material in and the engine goes under load.
Ive changed fuel filters,both screw on and in-line,checked fuel lines
drained tank and flushed it,checked tank pick up point,but yet it still does it!
could it be a dodgy stop solenoid that isnt completly releasing when turned back on and as soon as you vibrate the machine it jumps back to the off position?
baffled
also told it could be the diesel bug,but i would of thought it would cough and splutter than just die as if youd turned it off?
Hello
The symtoms you describe would certainly point to the fuel shut off solenoid interupting the fuel flow to the injector pump. This may not be the solenoid itself but the 12volt power supply to it.
You may have worn contacts in the ignition switch itself or a damaged/corroded wire somewhere within the circuit from switch to solenoid.
Hope this info is helpful, if you still encounter problems give Timberwolf Technical Support a call on 01449 765820:001_rolleyes:
