Got a pulleysaver on the way and wanted to experiment with some of the configurations.
Has anyone used the equalising configuration like in this vid ? (skip to 2.50) If so , what did you add to the system ? They mention a semi-ridged eye.
[ame=http://www.youtube.com/watch?v=D_zDuHgVbBk]pulleySAVER - YouTube[/ame]
And also has anyone used the 3-1 hauling set-up with a DMM revolver added ? (skip to 4.05) If so , does it work with a simple distel or will it only work with a hitch climber (i can't see it working with simple set-up) ? Really fancy this for going back up after lunch. :001_tongue:
Thanks,
Jim :confused1:
Edited by slimjimvw
Spell like a 5 year old.
the 3:1 works really well, great if your going up n down, up n down. does use a bit of rope though. If you set the revolver in the correct orientation, it still retrieves as well.
