Any one know where I stand if I use a borer tool to take a core sample on a few trees that have a TPO on them so I can carry out a survey?
Think I know the answer but I just wanted to get peoples opinions/views.
Cheers :001_smile:
I'd only ever use an increment borer as a final resort in a tree which I knew had serious issues (poor hammer soundings, picus readings, very poor crown condition, extensive fungal brackets etc) to determine, for instance, remaining wall thickness in a stem.
These tools are generally used in a forestry setting to determine relative growth rates.
What are you trying to find out with this test?
In terms of your question, I would say that a TO may have a view on you injuring a protected tree with a tool like this, depending on the validity of why you were doing it in the first place.
I didnt have to use one in the end, i was told that i might need one because the trees were "very rotten", all they had were some mechanical wounds that weren't to bad.
