  • Replies 43
[ATTACH]120954[/ATTACH]
Here is the one i had made, its simple but very afective!
I spy some kind of bag holding frame at the end of your conveyor! Any more photos? Given me an idea what to make now :)
Sent using Arbtalk Mobile App
Yes its just a simple 2x2 wooden frame, was thinking of getting a metal one made but just made that in the mean time, cost about £5 and has lasted well over 100 cube so far. Not going to bother with the metal one now. Will try and get some better pics on the weekend
  • 4 months later...
I've found this thread again to say thank you to whoever suggested using a tipping trailer as a log-deck. Having put the finishing touches to the grapple on my 360. I thought this set-up through recently and started to process my winter supply of firewood. Brilliant! No more heavy handling pieces of cord which was the worst part of this job as far as i was concerned.
There are some finishing touches to do like fitting a set of rollers at the bottom of the trailer to make it easier to push them into the machine. Plus an extension piece of hydraulic pipe to tip the trailer more or less. All the bits can be put away for the winter as it isn't permanent. I even have a use for the sawdust.
I can use my bag support frames in the trailer too, filling two bags at a time and a another pair on the ground, then move them into a covered area where the wind will continue the drying process.
codlasher.
