150 DHB switching itself off - Ghosts??
Hi,
Every now and then my 150 DHB switches itself off in mid chip.
Fuel tank is always full and the beast regularly cleaned and serviced.
I think the vibrations my simply shake the key to the stop position?
Any thoughts?
Many thanks.
Larry.
Hi Larry
Have has several customers report this effect
Have found 2 possible causes,
The first is that the key for the machine is attached to a bunch of other keys and the weight of the bunch has caused the key to turn and stop the engine. The second is a slightly worn ignition switch which combined with the weight of keys has emphasised the situation.
A further cause could be the start of the breakdown of the fuel solenoid valve but this would be unusual.
Hope this points you in the right direction.
regards
TW Tech Support
