yup i saw the pulley they are for rescue situations only. it was used in a 4 way pull to tention a speed line but under tention the cam cannot be released, so a pulley and a friction device would need to be added between the isc pulley and the anchor. just makes the tentioning of the speed line very complicated!!
It is more like the standard triangular shaped pulley with an extended plate below with an open cam shell, like the petzl ascension. It was red and running up to 13mm.
I know what you mean about releasing the line but all the same I WANT ONE :001_tt1: I believe that they had a single AND double pulley.
