Printer recommendation for ipad 2
Mark James
I got a hp photosmart plus b210a. Has e print and AirPrint. Get the hp e print app to go with it too. It's a bit finicky to set up but does work. Mine is a bit temperamental but I think that's my wireless network causing the issue.
I got mine from comet for £55 Was £15 cheaper than currys. Make sure it's the b210a model you get as there is a b210 that doesn't have AirPrint! The box for the printer will say compatible with iPad but only says it on one side so check for that.
