Think it was just turned up too far. :blushing:
how is it adjusted? while only pumping oil at full revs I changed the "screw" in the breather for a fuel filter and it floods out -- starting to wonder if plastic worm drives give up because of high oil tank vac:confused1: back to the drawing board:001_smile:
  • Replies 35
that's interestin' I assume you mean chain sprocket the larger 44cc (rarer model) has a 7 tooth drive sprocket but the worm is the same p't no
No, the worm is different because the Ryobi will only mate up with a six tooth sprocket and the Komatsu with a seven.
I'll have to take some pictures.
There's a screw underneath. I'll add it to the photo list. :thumbup1:
  • 2 months later...
The one on the left is the Ryobi one that Cheshire Cat sent me.
As you can see, they're the same shape & size, the only difference is the number of teeth which makes them incompatible.
  • 3 weeks later...
