Hello, I have New Holland 8360 that is flashing a F37 error code. Does anyone know what this is or where I might get a link to the error codes for a New Holland?
Thanks.
The linkage is working fine. All the A,B,C gear lights are flashing. The tractor first would not go into reverse now the forward gears are gone.
ahh.. now that sounds bit more serious.. i'm sure it'd be summin electrical or summin simple.. our 8630 lost all drive completly.. a valve on side of gearbox was stuck.. what area are you in?
I had someone to look at the tractor and they calibrated it and off she went for a few more weeks before the problem returned. I have had a garage to look at it at they are going to replace the 'pentameter' to see if thats the problem.
Johno1
Limerick
Ireland.
ts110 on farm lost forward and reverse and all gears it was the brain that stopped working to say its amodern tractor had nothing but problems wiv it its only done 3000 hrs the old 6410 has never broke down or had any problems
  • 3 weeks later...
Just to let you know that the problem with the tractor was sourced to the 'poteniometers'. The garage fitted 2 of them and the tractor is working again.
Thanks to everyone who responded.
  • 8 years later...
