SRT help
the verminator
yesterday at the Arb show i had a go at SRT under the helpful eye of Taylor Hamel. I liked it and decided to go and get some bits and bobs to make my own set up, so got hand acender, croll and foot acender. put em all together and can get up a tree, kind of , but how do you get down? :blushing: iv been switching onto a munter but cant switch from acending stuff to the munter very well. is this right and how do you switch over?
cheers,
Gary
btw with Taylor i was belayed out of the tree
  • Replies 62
haha looks like i'm not the only one bitten by the SRT bug!:thumbup:
I had a go with Taylor as well and he showed me a change over using a descender which was attached to the same line as the croll and hand ascender (not sure if it was above or below the croll) and then you take up your weight into the descender much in the same way you would when alternate lanyarding so that the descender now holds you rather than the croll or hand ascender and then simply detach the ascenders. I THINK!!!:confused1:
I'd be interested to see how you change over onto a munter's hitch and also a fig8 as i think that a less gear intensive/streamlined route is how i want to go with SRT...:001_rolleyes:
This was shown to me at the show it gives you the ability to self rescue, I've tried it and it's great but lots of friction on the distel! However by using a prussic above the ascender it gives you twice the friction which helps with decent. Sorry dodgy pics but gives the general ideaImageUploadedByTapatalk1307909523.771738.jpg.a3b38b84a7962487c12e838834b1a37d.jpg
So are you using the HC instead of a Croll and lower down at pelvic attachment height rather than chest height?? does it affect balance on the rope? I've seen the HC used as a hand ascender before but not in that type of setup...
I'm with you on the more money thing Vemrinator, no way around needing the gear to go up but coming down i feel can be stripped back a bit. though with experience i may decide otherwise...
Edited by ben-jammin
ah, does that replace the croll or as well? also how do you get the hand acender off the line with the weight on it, which it must be as its pulled the hitch up?
Edit:
sorry ben, just read your post
You have a 9inch gap between hitch and ascender so you stand up on the pantin slide up the hitch lower your weight onto hitch allowing ascender to be un clipped.
