I think the issue is that your not supposed to install any heating appliances that aren't CE marked so you may struggle if you ever need to make a claim due to fire caused by a home made stove.
Talk to your insurer, the NFU may be the most helpfull in this situation. If they agree to insure your property with a home made stove inside that has not been signed off as safe to use then get that confirmed in writing and away you go. I would be very surprised indeed if any HETAS installer or building inspector would sign off a non CE marked stove as safe to use.
By the time you have worked out cost of materials, time etc then I would be surprised if there is a lot to be saved.
A
