hi
one of the rotor fans needs replacing on a 150 of ours so just wondering if its much of a job to do these in our workshop , there doesnt seem to be any obvious way into them , any clues?
Hi Karl
If you have broken a fan you cannot replace a single fan side.
The fans have to be replaced as a pair because the rotor needs to be balanced and it cannot be guaranteed that the rplacement is the same weight as the original , hence it is highly recommended to replace the pair.
It is a reletivly easy job to do
Slacken and remove the 3 drive belts
Remove taperlock and drive pulley from shaft
REmove the rear bearing housing
Remove the hopper and feed tray
Take off both motor and slide from the drives
Remove the Roller box assembly
Remove front plate complete with rotor assembly
When you replace the fans use the same nuts and bolts in the same holes as there is balancing washers under each bolt and these to be put back in the same place.
Clean rotor face and remove any debris
Torque bolts up to 30 then 40 & then 50 lbs ft in sequence
refit the front plate then refit all parts in reverse order
If you are not confident to perform the work we would recommend that you seek assistance from a TW dealer.
hope that this helps you
regards
TW Tech Support
