its just as likely that sharpening is the issue. Also these big bars have a lot of flex in them as it is, and can be 'steered' when cutting. Its possible the operator is putting too much effort in to cutting, either because the teeth arent sharp enough, or maybe even he struggles with the weight of the saw.
I'd say its unlikely you'd bend a bar doing a plunge cut though unless you're doing something very wrong
ditto
