Ben, I should be going down, think it could be a good laugh!
Gustharts are on the CE, how long?
Originally they said end of April beginning of May I thought.. But who knows.. If they take much longer I will get one shipped in:sneaky2:
  • Replies 85
If you got one hand ascender it would open up a lot of different set ups. But as Drew said, test it out with a HC or something with a footloop to see if you like the setup..
With a croll and a pantin you could set up a 'rope rocket' mentioned in this document from VTIO. Ive done it with HC (with a webbing sling made into a chest harness and clipped in the middle hole), croll with a short footloop as a knee ascender, bungeed through the bottom HC crab back down to the pantin on the other foot.
It is nice if you cinch a TIP, cos you can SRT up, lanyard in and switch over to your normal climbing system with your HC already on the rope.
http://vtio.org.au/Content/wp-content/uploads/2010/07/Single-Rope-Technique-i.pdf
Cheers for the link ben,Do you mean use a HC instead of the mini traxion?
yep. hey ben, how do you find it? i find it way too cramped to be worth the effort but it is efficient on the real big ascents
I can't see why more people don't use SRT for work positioning and not just access? With a unicender you get into the tree and start work! It seems a lot of fuss to gain access into the crown and then switch to ddrt? There is the problem and safety issue with switching from one mode to another, although not if you are stropped in correctly.
With just a croll, hand ascenders etc you can only go up! It's a right pain to descend even the smallest amount!
To me it makes sense to spend some money, a lot of money! And buy a Unicender, it does so many things and has so many uses!
I have also used a floating croll with a foot loop and throw your lanyard over your shoulder and into the Unicender to self tend the system, pantin on foot.
I am trying the croll with a chest harness but I am not happy with it. Good at ascending but it can pull on the neck when work positioning even with it unclipped.
Edited by Paul Smith
if you get up to aucks bro we will have a couple of unicenders for you to have a play with-i personally cannot get on with srt work but love it for access.
Think im just going to get a basic srt set up to start with then have a play around with different ideas
Good idea! I used a helical from the Unicender as a back up and to help with the switch from ddrt to srt.
