Hi folks,
A while ago my entec treebusta blew its kohler command engine to pieces. I am going to get a cs100 when funds allow, but in the short term have decided to replace the engine on this machine as all else was good. The treebustas as far as I know were sold with the kohler command or honda gxv engines which I understand (though not sure) have the same mounting.
Looking for a bit of advice as to which engines will hopefully bolt straight in. Am I correct in thinking these engines are interchangeable ? Will a Briggs engine of similar hp fit (i know the shaft size will need to be correct) or are there others could use? It's not worth spending much money on this machine, so it's going to be a second hand replacement job.
Any thoughts or advice much appreciated Thanks
