as anybody used these on a quad???
look like they are designed for sand and snow, not sure i would trust that tread to cut into mud well enough not to slip about, also it has no directional pattern to it, so whats to stop it slidding sideways rather than gaining forward traction. why not look at a set of clic duals with kenda bearclaws or executioner tyres if your serious about working on slopes
Have you ever wandered why tractors shifted from steel wheels with tall grousers to pneumatic tyres with more but shorter grousers?
Wile you may think it was so they could be used on the road which was a benefit, it however was actually because pneumatic tyres in a field would produce more pulling power and save fuel as the tyre can conform to the undulation of the ground and offers a larger footprint.
Looking at the ‘21” growser paw’ with its triangular shaped relatively hard grousers they are not going to produce traction on tree roots and if you get near a made up track it will be a bit of a bone shaker and reduce speed, also tyres have a smooth finish beneath the tread blocks so there is the minimum surface area for mud to stick to so along with the deformation of the tyre and the pinching together of the tread blocks helps with self cleaning, however with the ‘21” growser paw’ it had corrugations effectively increasing the surface area for mud to stick to coupled with limited deformation to help brake the mud’s stiction, so I wouldn’t want to go near a damp clayey soil.
You can get them of landys too I would so love a reason to buy them!
http://www.versatracks.com/gallery/index.htm
that is nothing new either in design which they have basically copied or in application an a land rover that was done >40 years ago.
however this rises obvious questions of suitability on a disco as you would damage bodywork/tracks in short order. :001_rolleyes:
