Howdy folks
Just wondering what the correct technical term is for the type of sharpening used for these sorts of blades. Presumably it has to be a slow revolving unit with cooled grinding surface. I've rung a couple of places but i'm not sure if the understand the significance of the chipper blades properties, and wouldn't fancy some eejits taking an angle grinder to them.
Some are hollow ground some aren't. Should be obvious by looking at the profile of your knives.
Any good machine shop should be able to do it, machine knife grinding is what you need to ask for.
