Hello,
I recieved my Alaskan mill the other day, (thank you Rob for a prompt service) I'm about to start milling some spalted beech I have and i'm looking to build my own kiln.
I don't have room for an old freezer box so I thought I would insulate a shed I have. My question is what size of dehumidifier should I buy?
The shed isn't too big, about 5' wide by 10' long and around 6' high. Should I buy as big as I can afford? My budget is around £200. Or can I get away with a smaller one?
Also is there a book on the subject anyone can recommend? Any help would be great or links to other relevant threads (I have done a search!)
Cheers
Richard
There's some fantastic information on Woodweb.com if you need to get some very sound opinions on milling and drying, on a large and small scale.
Search Results from WOODWEB's Site Search Engine
From what I've read in the past, a lot of folk don't recommend using domestic or light industrial dehumidifiers for timber drying as the acids and tannins from the timber will corrode the internals of the machine. I've not had any experience of using them myself tho....
Don't send a home dehumidifier -- to do a commercial kiln's work
I'd just buy a dehumidifier off ebay to start with. If you keep an eye open you'll get one for a good price although summer time is when the real bargains are.
Other than that as Big J says above.
Do a bit of reading on the net but don't worry overly much as experience is one of the best teachers.
