Is this the right bearing for my tw125
NSK 6205du
Seams to cost £3 and has not lasted 6 months in my chipper i know the company that did it charged me alot more than that, this company also did not change my main bearing even tho asked.
any info appreciated. My old man used them and his bearings collapsed within 3 months :thumbdown:
depends where you get them try to get an SKF or RHP bearings there good !
They wont cost vast amounts there is such a mark up on bearings its outragous !
also have a chat with the bearing guys there may be a different seal type that would be better suited to the aplication maybe !
i know i have changed some rubber seaqled ones for metal seald ones for rough use they keep out muck and rubbish better in some apps !
A lot of bearings used in machines are standard bearings that equipment manufactures give their own part number and charge a fortune for.
Critical dims are outer diameter, inside diameter and width, once you have this, go here - Simply Bearings Ltd ~ Oil Seals SKF FAG TIMKEN KOYO NTN NKE TRULOC Needle Rollers Taper Rollers Rod Ends Oilite Bushes Loose Balls O Rings Grease Plain Thrust and use their configurator to find the bearing for you, be sure to specify open or closed races as required etc
Spud
