I have had a big mill for the last two years & have been milling mostly softwood with fairly good results.For one-offs its a bit slow to set up and if you are going to mill more than 2.5M you really need two centre supports(or whatever they are called) I have also had a few probs with the screws used to hold the arms onto the end of the logs - you have to use round heads because countersinks move the plate out of level.This apart its a well made piece of kit but my old 262 is to be honest struggling & im looking to buy a second hand saw of at least 70cc5476970286
Thanks For your posts. I just keep getting beautiful timber and it seem such a wast to Cut it up for fire wood.
Get a 36" Alaskan then and if you start doing more get a logsol or a lucas mill.
Start cheap so you don't end up with something much more expensive sitting in the workshop.
