Fibre buckling is usually a sign that the internal wood of the tree has decayed and is collapsing. Imagine a hosepipe. When it's in use and the water is gushing through it under pressure the hosepipe stays firm and strong. When the water is turned off the hosepipe is more flexible and can collapse. Similarly, a tree will shift, buckle and collapse when the inside softens due to decay and the remaining structural load-bearing sapwood can no longer support the weight.
Β
Fibre buck;ling occurs with or without decay....
Β
This is due to wood being stronger in tension than in compression. When a wind force is strong enough it can cause a tree to be stretched to its limits, a buckle can form, and perfectly normal.
Β
It also does not cause a weak point in the stem, it actually becomes stronger due to the twisted fibre lay and higher lignin and pectin (super adhesive) content.
  • Β
Arbtalk.co.uk is a hub for the arboriculture industry in the UK. Β
If you're just starting out and you need business, equipment, tech or training support you're in the right place. Β If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom,Β Β then you're welcome too.
Γ—
Γ—
