Very well, couple of teething problems with knackered belts that only got worse when I got it but put a new set on and it was like a different machine. Sprayed some belt dressing on and kept them tight and it is surprisingly good! 4" is a fair size piece and although it takes time feeding bit bits and is difficult to feed logs without thinner branches and leaves on it's just technique when sending that means you can feed them easily.
  • Replies 50
