I have found for sale a
A Weima Brikettiertechnik TH40 briquetting machine no.
950-904 with hydraulic ram,
conveyor feed system, delivery
piping to skip, Protimeter
moisture meter and
accessories
The bricks they made looked abit loose so not sure if this machine has enough pressure ?
moisture meter and
accessories
I did look at a similar machine but rejected when I saw the quality of the briquettes it produced. That said, now knowing the variability of briquette production it could have been operator error. Ask to see it running there should be a pressure gauge from the piston ram for a decent briquette you will need between 80-100 bar pressure any less and it will be poor quality. Also check the die for wear as a new die is not cheap.
