Hello again,
My TW18/125 seems to have developed the feed roller problem described in some earlier posts. Roller stops turning forwards even when green button is pressed. Blue button makes it reverse fine. Only way to chip is to hold green button down which moves roller forward, releasing it stops it when it should continue.
Does mine still use the SRB500 relays? If so, where are they on the machine? It has had a new no stress unit a couple of months ago which was purchased from my TW Dealer, Gunn JCB. It was an aftermarket unit as I was told TW no longer stocked no stress units for my machine. Could this have a bearing on what is happening? The no stress function works a treat normally.
Many thanks,
Adam
